Use automatic virtual links to provide an automatic, dynamic backup link for vital OSPF traffic.
  • Enable OSPF globally.
  • Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
  1. In the navigation pane, expand Configuration > IP.
  2. Select OSPF.
  3. Select the General tab.
  4. Select AutoVirtLinkEnable.
  5. Select Apply.
